landyacht318
Oct 27, 2019Explorer
Meanwell, not Maxwell.
My rsp-500-15 does not meet its specs, it exceeds them. The voltage range they claim is well under what I measure too
As I said it will go right to 40 amps, and stay there as until battery voltage rises to the voltage setpoint I have chosen before I plugged the dc powerpoles together.
My inline wattmeter says 40 amp, my shunted battery monitor, with all loads shut off will read 40 amps, my clamp on ammeter will read 40 amps. I actually have 3 more wattmeters I can plug inline with the one hardwired onto the meanwell and all will agree within 5%. 40 amps to seek and hold any voltage between 13.12 and 19.23v, well I've never tried to get it to provide 40 amps above 16.2v
I doubt the unassisted heatsinking and the small yet extremely loud and powerful 40mm fan, by itself, would have allowed 5 years of regularly outputting 40 amps, but with it I have no fear of running it flat out.
I have added a 60mm Noctua fan blowing inward, and an 80mm fan exhausting the steel lid of the casing. These fans keep the loud 40mm fan off completely under 64F ambients even at 40 amps, but it will still come on at higher ambients when passing 40 amps for a while.
Without the extra fans the 40mm internal loud fan would cycle on and off with as little as 6 amps.
I think you have to factor in these or at least some ventilation and heatsinking modifications to the meanwell vs powermax, which leans more heavily for the powermax.
No speed control of the fan, like on PD 92xx series converters.
The heatsinking I added, visually appears to be overkill, but they do get quite hot.
As hot as it gets, I've never seen it not be able to maintain 40 amps when the loads could still ask for that much.
the existing trimpot on the meanwell is not even one of the nice blue 20 turn trimpots but one of the 3 legged 270 degree tiny pots that are super difficult to adjust precisely.
I had to completely disassemble the meanwell to get to the underside of the circuit board to remove the voltage trimpot and install wires. Doing this requires removing the transistors from the casing. The thermal grease makes this a potentially messy job. Snipping the legs of the trimpot to add wires to those legs would be better if one could manage that, access is tight.
If going for the full disassembly, have more thermal grease on hand.
I don't know for how long a pair of flooded T-105s depleted to 50% would accept 40 amps, but I'd likely want more than 40.
My 50% depleted Northstar 90Ah group 27 when new would accept 40 amps for about a half hour before reaching 14.7v. 65 amps for about 22 minutes before reaching 14.7v.
I don't run a generator to recharge so the VA is not a concern for me and the PFC nature of the Meanwell is not truly appreciated.
Fast as possible recharge times are also not a requirement of mine, but this Northstar AGM has proven to crave high amperage from a well depleted state to restore performance when lots of full or nearly full recharges by low and slow solar only had voltage maintained under load for the same Ah removed from battery lagging..
How long the battery can accept 40 or 65 amps is another observational datapoint I've been collecting since september 2014, when I acquired and started employing the Meanwell, and the Northstar was already 10 months old by then, but used more as a stating battery and cycled only when my other flooded battery was getting EQ'd which was 2x a month.
That other battery lasted ~500 deep cycles before I removed it from rv service in june 2015, but it is still going in workshop duty powering leds and fans. My Northstar then was doing double duty, cycling and engine starting while I was modifying the battery tray for a GC-15 sized battery and has been doing so alone, ever since.
The Northstar proved so able to meet my needs I never completed that battery tray project and have been been cycling and starting my engine on the same battery ever since. I can carry 66% more battery capacity, I just don't need to, or want to.
You will get a lot of philosophical answers regarding charging of batteries. some will say just get this and you will be 'just fine' and there is no need to stress these little things.
I can tell you are a tinkerer and there is appeal to modifiying things and seeking ideal, to achieve ideal as possible battery life, within reason.
I'm not trying to steer you to the Meanwell, just giving you all the info I know about it from having used it for the last 5 years as a battery charger, and a converter, and a float charger, and a maintenance charger, and yes, also as a power supply without a battery in sight. I'vwe put some hours into modifying the meanwell with more heatsinking and ventilation and the external trimpot and wattmeter, and also making sure the wiring to and from it was not stressing the circuit board receptacles. While the powermax casing is hardly as sexy as a garage charger marketed to the mass public, my meanwell is downright ugly with heatsinks and fans and wires sticking out all over the place, but its performance cannot be argued with.
If my needs changed, and I were to require more battery capacity, I would want more charger, and would get a second meanwell and parallel them. A diode or 2 might be necessary. When I parallel the schumacher they combine their amperage until battery voltage rises to the max setpoint of the schumacher, which might be 14.7v or 16.4v, as the Schumacher is an unreliable whack job with little consistency.
I have some voltage drop on the wiring so can exceed my voltage setpoint, and charging at 65 amps does raise battery temp quickly too, so I am there to keep voltage from going too high as amps taper and voltage drop becomes less of an issue. but in general I want max possible amps until 14.7v is reached. I dont want them tapering at 14.3v battery voltage because of voltage drop on the wiring, even though it likely makes little difference in charge times to truly full, or battery longevity.
While i say i set it to 14.7v then pthen attach powerpoles, If I am paralleling the schumacher I start the schumacher first and get it to do 25 amps, then plug in the meanwell and will crank the voltage dial as high as needed to insure 40 amps output, as there is some shared wiring to the battery along which the voltage drops at high amperages.
There are also some cheaper 30 and 36 amp Megawatt power supplies that are similar to the meanwell if the $ per Amp is the endgoal, and cheapo 30 amp powersupplies with adjustable voltage which appear visually identical to the megawatt available for as little as 18$, I had one but it had no thermal or current overload protections. It was rated for 30 amps yet would exceed 38 amps. and did so for 17 minutes when I got tired of twiddling the voltage pot to keep it under 36 amps, but close to that, before it released the magic smoke, and I ordered the meanwell minutes later.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
