jseyfert3
Nov 03, 2019Explorer
Yes, I know that while recharging the voltage doesn't have anything to do with SOC.
The nice thing about the hobby charger I'm using right now is that it displays the actual charge current and keeps a running total of mAh delivered. Right now, the current is down to about 6.5 A and the total Ah delivered is approximately 50. At 60% SOC I'd expect around 100 Ah will be needed, plus charging losses, minus the reduced capacity new deep cycle batteries have, but it's still probably a good first past indicator of the battery health.
This might be the first time I "roll over" the mAh counter on the hobby charger, since it only has 5 digits. :D Typically, I'm charging 2000-3000 mAh lithium battery packs, not massive lead acid batteries.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
