shastagary
Mar 26, 2018Explorer
the antenna should be mounted as high up as possible so it has the most clear line of sight to the sky in all directions possible. is that antenna the small magnetic mount antenna? it also should be mounted so the magnet is facing down as if it were magnet mounted to a metal car roof to get the best signal capture.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
