MrWizard
Jun 01, 2018Moderator
1000w is tool small
you are trying to charge and power the fridge
the start up surge of the fridge is most likely the cause of the overload
get a portable charger, plug into the yammy, do not plug in the RV
for a test, turn off the fridge, plug in shore cord to generator
make sure wh is LP only
see if the batteries will charge
after the charge load drops down, you might be able to turn on the fridge
the fridge will stay cold for (2) hours no problem
if you don't open it
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
