time2roll
Jun 02, 2018Nomad
Winnipeg wrote:The Yamaha will put about 35 amps max into the battery. If you can set the inverter/charger at 30 amps, set the fridge and water heater to propane only you should be good to go. Not really going to work with residential fridge.
Thanks for several great suggestions. The Yamaha puts out 900w max, and I don't plan to buy a new one, so I will get the biggest external battery charger that it will handle.
Follow-on question: when I run the main RV generator (5.5 kw), the built-in inverter/converter charges the batteries. What would happen if I ALSO use my new external battery charger? Both of these are smart chargers.
A 30 to 35 amp portable will work fine too. 20 amp is fine also... just takes more time.
The Yamaha 12v direct charge is maybe 8 amps if you do not use eco-mode. So very slow and extra noise.
I recommend this converter over the battery charger:
PowerMax 35 amp Boondocker
Multiple charging sources will not create any issues.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
