wanderingaimles
Jun 23, 2021Explorer
What is your battery situation? You mention having the inverter, and apparently have tried using it. I know others in here have more experience in this than I do, and hopefully one will chime in, but,,,,,
Can you run the AC from your batteries, via the inverter?
If so, can you run a stand alone battery charger from the generator to boost the batteries?
It likely wont keep up, but if you only want a couple of hours a day of use, and dont mind running the Genny for a couple of additional hours to replenish the batteries, you may squeak by.
What I am asking is,,,
IF you turn off the converter
run the AC from the inverter
and then run the genny, powering a separate standalone battery charger, could it work for limited periods of time?
