3_tons
Jun 25, 2021Explorer III
These testimonials are fine, but can sometimes be a bit anecdotal depending on one’s own particular situation because there can be many variables…In my case the soft-start didn’t solve my eco-mode engagement problem, and outcomes can vary depending on type of inverter used (i.e. OP’s hybrid type vs non-hybrid pass-thru type, vs NO inverter in the loop), as the generator may or may not not be the actual problem source…Where there’s no inverter in the AC system loop, it’s a far more straight forward proposition, however (if a pass-thru load-sharing type inverter like the OP’s…), I would first try to bypass the inverter to see where the root problem lies…
3 tons
3 tons
