3_tons
Jun 25, 2021Explorer III
Itinerant1 wrote:
I use the eu2200i with the Magnum 3012 hybrid inverter running a Carrier Air V 15k air conditioner with a Micro-air EasyStart™ 364 Soft Starter that I added. Before adding the easy start it was hit or miss if the Magnum would fault since adding it hasn't been a problem even at 6,000' elevation.
Just curious, but did you try lowering the voltage cut-out??…Thanks,
3 tons
