BradTX wrote:
I'm going to test it again tomorrow. When the A/C kicks off, the display on the microwave starts dimming so I don't know if the problem is with one generator tripping first and then the other overloading or if the whole gen system gets overloaded at once.
Since the load is so much lower once running, maybe try pulling one of the generators out of the system while it's running. See if the problem persists with just one. That will tell you if there's simply a high load or an interaction issue between the two.
