MrWizard
Oct 16, 2016Moderator
glad you found an easy fix, for the simple but annoying problem
out of hundreds of thousands sold, and only a few exhibit this problem ?
Yamaha's normal production methods are probably sufficient
that bolt probably either did not get full torque when installed
or was just inside the tolerance spec for size, from the bolt MFG
