NRALIFR
Jan 13, 2021Explorer
Staying warm in -20 is going to take a fair amount of energy.
Airdrie is in Alberta, Canada north of Calgary. Considering the weather conditions he’s talking about hunting in, I can imagine he’s using every watt that generator can produce to stay warm overnight. Lows of -20 are going to make batteries less capable of providing needed power, and make it more difficult to recharge them.
Adding batteries to the wheel wells isn’t always as easy as you might imagine due to the shape of the bed where the side walls meet the floor. There’s a curve there on Ford trucks that make it necessary to raise the battery up a few inches to get the width needed for the camper tub. The Okanagan 811 is a basement camper, with the floor height above the wheel wells. The floor of the camper also extends over the tops of the wheel wells, reducing the available height in the bed areas in front of and behind them.
Placing group 24 or 27’s or 6 volt batteries there before loading will make the camper more difficult to load, and the batteries will be even more exposed to ambient temperature than the ones in the battery box. While more batteries is generally a good thing, In the conditions Chad is talking about, I would want to add them inside the heated space of the camper.
Basement campers don’t usually have access to the wheel well areas while the camper is on the truck, but non-basement campers like mine typically do. I’m already using the majority of that space for items that can fit through the access doors on each side.
I’m glad to see that there’s an extended run kit available for the Yamaha 1000 now. I have one as well, and 99% of the time it’s all the generator I need. It’s size and weight are much more compatible with my needs and available storage space than any 2000 watt gen. When I first got mine over 12 years ago I looked for an extended run tank, but there just wasn’t much available for it, unlike the more common 2000 watt models.
This seems to be the extended run system I see most often for the Yamaha 1000/2000 generators.
Bergs System YMH1.2000IS
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
