- jimmac28ExplorerThanks for all the info looks like I’m going with the Yamaha 2000’s, I’ve got a 15000 btu ac unit and two parallel 2000’s should do it. I like to the 44 lb so I can move them in and out of the pickup bed without any struggle, they will be stored in a tool box just in front of the hitch. I’m going to do some NASCAR infield camping so I’m looking forward to my first dry camping.
- pianotunaNomad IIIHi,
I'd look seriously at either twin Champion inverter generators, or the new 3100 watt Champion inverter generator.
Otherwise I'd go for the Yamaha 3000 SEB unit. - MeandMyLabsExplorerMy 2400is will run my ac but it failed to restart it on one hot day in June a few years ago. Made rush trip to get Champion and have not used my Yamaha since for ac. Twin 2000's are a sure thing, 2400is is marginal.
- mlts22Explorer III like how the Yamahas have a fuel petcock, which means that you can run the carb bowl dry for storage.
- Splashers3ExplorerI love my Yamaha 2000is....could only afford one at the time, but will be buying the second when I need it. Presently, all our camping is at c/gs with electric hookups. Now, some day when we go off the grid, we'll get the second one.
I also did the research, and decided blue was better than red...and initially I was thinking red. - BumpyroadExplorer
jimmac28 wrote:
Bumpyroad wrote:
why not one EF2400iS or EF3800i?
bumpy
Weight, the EF3000 weighs 136 lb where the 2000 weighs 44. A little more money but very convenient.
but one EF240iS weighs 75 lbs and it will run microwave, etc. I am still trying to find out if it will start/run a 13,5 AC however. at 75lbs it is less than 2 x 44
bumpy - ScottGNomadI would take the Yamaha over the Honda if I were to do it all over again.
- Jayco23FBExplorerHere is some more info I had saved on comparison of the two brands.
Honda pros:
- ton of dealers, no lack of service or parts
- a lot of units in operation since they came out first
- fuel pump so it's easy to add a bulk fuel tank
- Honda has the guts to post how long the unit can run with a 2KW load (30 mins)
- 3 year warranty, consumer or commercial use - doesn't matter which.
Honda cons:
- WTH? no removable cylinder head!
- plastic camshaft with a single lobe that is timing belt driven (how long will this last being in contact with oil?)
- plastic oil slinger disintegrates after 7K - 15K hours. Engine fails shortly after
- aluminum cylinder bore
- cannot run the carb dry as the shutoff petcock kills the ignition too.
Yamaha pros:
- conventional construction, cast iron liner, removable cyl head, metal camshaft
- fuel level gauge
- fuel petcock doesn't kill the engine so you can run it dry
Yamaha cons:
- a LOT less dealers and service centers
- no mention of the 2KW rating on this generator anywhere - Jayco23FBExplorerI have (2) Yamaha 2000. I love them. I did alot of research as I was interesed in buying the Honda as well. The reasons I choose the Yamaha are:
- The Yamaha has a fuel gauge.
- The Yamaha has a easy to access fuel shut off. (I have had fuel issues with the Honda 2000s).
- The Yamaha has a longer "rated" life
- The valve timing mechanisim was better on the Yamaha ( I forget now exactly what is was, Honda uses a belt.
Both are execellent machines and it took me some time and effort to decide, but I am happy with my choice. Check out Wise Sales online they have alot of information and are excellent to buy from.
As for using the generators I use the parrallel cables and run both units when using the AC (econo swithes off on both units) and if I don't need all that power I can run a single unit in econo mode and you can barely here it. One recomendation I have if you buy two units is get the hour meters I use the meters to equal out the run time. - jimmac28Explorer
bumpy
Having RV issues? Connect with others who have been in your shoes.24,339 PostsLatest Activity: Nov 28, 2025
