HighCover's avatar
HighCover
Yamaha EF2400is Surging Idle
My vintage 2007 EF has the dreaded surging idle. I pulled it apart and cleaned the idle jet, the main jet and the third pointy screw in the carburetor, and the dang thing still surges.
Even though I am in DFW, I can't locate a Yamaha service center anywhere near where I live.
So, I guess I'll sell it "as-is" and look for another unit, but not a Yamaha due to the lack of service.
Maybe a Honda, but I am thinking of the Champion or one of the lesser inverter generator brands.
Any suggestions? Only requirement is to run a 13.5k BTU unit in the Texas heat.
  • I second trying a bit of Seafoam first before giving up hope. You'll more than likely need a pair of 2K watt units to effectively run your AC, a 3K watt unit should be able to do it and Champion does have an inverter 3K watt genny that is priced well below what blue or red offers. Our genny is of 2007 vintage as well and I have always used Stabil and Seafoam to keep it purring along.
  • You can find Honda parts at most any gardener tool and repair shop. Can't say if that is true for Yamaha's, but parts for Honda's abound. Including new carbs, if it gets down to that.
  • I would recommend putting some SeaFoam (Available at WalMart) into the tank and run the generator enough to get it into the carb then let it set overnight and see if that helps. I add SeaFoam (1oz.) to the tank everytime I add gas. I previously used StaBil but found SeaFoam to work more efficiently since my generator may set a month or two between uses, usually starts on 2nd. pull.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
