Bobbo
Mar 02, 2019Explorer III
Tom_M wrote:
It's possible but I don't know what the troubleshooting procedure would be. Before you spend the bucks to replace it, try running a heavy dose of Sea Foam through it. My 1000 watt Yamaha would run rough unless partial choke was used. I ran some Sea Foam through it and that cleared it up.
Tom's suggestion is top notch. I have a riding lawn mower that got to where it wouldn't start unless I used starting fluid (ether) sprayed into the carb. Even after starting, I had to keep it partially choked. Before spending money on it, I bought some Seafoam and ran the mower with double strength Seafoam in it for a season. At the end of the season, the mower was starting like a champ and running like a sewing maching. After that, I use seafoam, at recommended concentration, in everything I own that takes gasoline, except the cars.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
