time2roll
Jun 26, 2015Nomad
The 4 prong outlet is going to split the power to have 23 amps on each side. If your 50 amp RV has one air conditioner on each side of the panel and everything else is off it might work better than you were advised. I would try this first. Turn ALL breakers off except the two main and the two air conditioners.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
