EnzoColorado's avatar
EnzoColorado
Explorer II
Dec 09, 2019
Yamaha Generator question
I'm brand new to using generators.
A few months ago I bought a new Yamaha EF2000ISV2 generator. When I hooked it up to my travel trailer and try to run the microwave, the light in the microwave flickers and I can hear the sound from the microwave is lower and fluctuate compared to when connected to a outlet. I tried both the smart throttle setting and the full setting, both result in the same thing. I also noticed when the microwave is on, the generator's motor's pitch and frequency seems to be lower. The microwave also doesn't seem to heat up food much. Is there something wrong with the generator or am I not using it correctly? n
  • Interesting. The PD converters, same as the others, do need about 105v AC minimum to do their amps according to their specs. They will still do some amps at voltages a bit below that.
    What that "105v" means for how the converter would "see" the AC with different types of generators is all new to me, but would be good to know since lots of RVs have those non-inverter gens.
    Xantrex used to warn about running their chargers on some gens where it was like they had MSW and wouldn't run right.
  • I only have a single 9610 to gather data from and am taking the risk of making a general statement from it. Posts over the years from other members confirm what I see at a circumstantial evidence level. The spec I see on the PD web page is "Input voltage tolerance", not "Minimum voltage for full output" or something similar. Maybe it's stated elsewhere that I haven't seen. What I've seen for myself is that the 9160 needs a 120 volt or higher sine wave to achieve its rated output. Like a conventional microwave oven, it appears to rely mostly on the peak voltage of the input power. If the sine wave is below 120 volts RMS, or the waveform is flattened as happens with many conventional generators, the peak input voltage is too low for maximum DC output. This is opposite of a WFCO converter that (when it's working) provides its full DC output when driven by lower voltages and/or lousy waveforms.
  • gatorcq wrote:
    MSW Vs PSW is the issue.
    If I can redefine the "M" to mean mangled, I'll agree. My PD9160 will not supply its full power when powered by the kinda-sorta sine wave from the Onan microquiet. Driven by an eu2000i, it meets the specs.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
