time2roll
Mar 22, 2017Nomad
jdmountains wrote:Need to locate and post the model number of the breaker/fuse panel would probably do it.
I put in the $250 range. As for the on board charging system, I have no idea what that is. How would I find out what the on board charging system is? Why would a converter determine my power requirements.
Some may need 800 watts, some may need 1800.
If you are buying a 3000 watt champion generator then you are right that it does not matter.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
