theoldwizard1
Mar 23, 2017Explorer II
jdmountains wrote:
I might just go with the Champion 2000 watt inverter model. They are $441 on amazon right now and should do the trick.
Good idea !
I am guessing those batteries a dual purpose marine batteries. You would be much better off with a pair of (Costco) GC2 golf cart batteries. If you do a lot of boondocking, I would suggest 4 of them. Two pair in series and then in parallel.
Recharging TT batteries from a tow vehicle typically does not work well because there is not enough voltage at the TT battery connection. There are solutions but they cost $$$$ !
