2nasty's avatar
2nasty
yes another ryobi issue
Why is my Ryobi inverter generator 2300 bta overloading as soon as its started with nothing plugged in , also I noticed that the display indicates that its pulling more watts to run the same load that it was previously using less watts to run I have replaced the carb, sparkplug oil ,fuel filter air cleaner problems is still present I have not changed the stepper motor however I did check it with a multimeter continuity was good reset button also working any suggestions
1 Reply
  • Nothing plugged into the generator and says overloaded?  Seems like an internal short or internal electrical control issue.
    Probably needs a pro to look at it or if new a warranty adjustment.
