Sort By
- pianotunaNomad IIIAre you measuring at the battery bank or at the terminals for the detector? They use thin wire to save a dime, so there may be voltage drop.
- BFL13Explorer IIIt is odd, so needs checking for sure. First thing would be to use your multimeter to check the voltage right at the detector connection in comparison with actual battery voltage at the house battery.
Never know, it might have a loose connection somewhere giving high voltage drop. Some LP alarms have a little glass fuse there too. You can get big voltage drops across a glass fuse sometimes, where they snap in at each end.
Having RV issues? Connect with others who have been in your shoes.24,243 PostsLatest Activity: May 11, 2025
