- pianotunaNomad IIIAnd the voltage at the battery bank was? (and perhaps at the other place you were measuring?)
- DarkSkySeekerExplorerThe voltage at the detector (with the coach plugged into shore power) is 13.1 volts.
pianotuna wrote:
Measure the voltage at the detector.
Will do that tonight. - IvylogExplorer IIIThey should be sold as audible low voltage alarms...normal operation.
- pianotunaNomad IIIMeasure the voltage at the detector.
pianotuna wrote:
Are you measuring at the battery bank or at the terminals for the detector? They use thin wire to save a dime, so there may be voltage drop.
The 11.8 volts is measured at the cigarette lighter "port" on a USB charger with a voltage display. This is in a panel near the cable/satellite connection. - wnjjExplorer II
DarkSkySeeker wrote:
My CO detector goes off when the coach batteries reach 11.8V. Most specs I've found indicate detectors run all the way down to 7-8 volts. Is mine at the end of life?
Maybe the spec simply means it will still sound down to 7-8 volts, not that it will sit there quietly and function down to there. You want significant overlap between false sounding and completely dead or a rapidly discharging battery would go from detecting (but quiet) to completely quiet without warning. - DarkSkySeekerExplorer
rwynkoop wrote:
My detector is new. I replaced it once thinking it was defective due to the beeping.
After replacing it, does it still beep unexpectedly? - RJsfishinExplorerMy wired detector woke me up for the very last time a few yrs ago,...if ya know what I mean.
- rwynkoopExplorerI see the same thing with my wired co detector. It starts to beep around less then 12v, 11.8v sounds about right, but the furnace was also running hard on a separate circuit. 11.8 is measured by my solar controller, near the battery.
Robert Wynkoop
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
