joshuajim
Mar 17, 2018Explorer II
SoundGuy wrote:SpeakEasy wrote:
Reading the discussions here recently I learned about Micro-Air Soft Start . In exploring their website I learned how this device is installed and how it enables a 2000-watt generator to power the ac.
Strictly speaking, that's not actually the case ... the Micro-Air Easy Start Soft Starter Kit allows any generator to more easily deal with a reduced A/C compressor start up load but will do nothing to improve it's chances of continuing to run with any genset that's only marginally rated for the load, only a bigger genset can assure that. Exacerbating the situation is that as ambient temperatures begin to rise and elevation increases beyond sea level so too will the A/C compressor put an increased load on the genset so although an Easy Start will significantly improve chances of the A/C starting it won't guarantee it will continue to run when temps are particularly hot and elevation especially high. Believe it, that genset will still be running at a pretty good pace whenever the A/C compressor is also running so it may not be as quiet as you think it will. This genset has a 98 cc engine, same size as the EU2000i, while the new EU2200i has a 121 cc engine, which logic tells me would be more likely to keep an A/C compressor running when ambient temperature and elevation are a concern.
So true.
I ran a test with my Yammy 2400 at 3500 msl and 106 degrees. That equates to 7300' density altitude. While the A/C started without a hiccup, as the head pressure built up it took 2040 watts to keep it running. Starting was not the problem, continued running was.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
