SoundGuy
Mar 21, 2018Explorer
ctilsie242 wrote:
I personally think the MicroAir product, or hard start kits in general are a must. Mainly because 60+ locked rotor amps is not going to happen with most RVs unless one is plugged into shore power. Moving the inrush current to a separate device not just allows for a 2000-3000 watt generator to be used, but also extends the life of the A/C compressor, since it will encounter undervoltages far less often, and too low a voltage does more damage than too high a voltage often.
Agree completely. I'd add an Easy Start to my own Dometic Brisk II in an instant even though I always run mine on shore power EXCEPT for the fact that we use the A/C so seldom, perhaps 2 or 3 times during the entire season, that's it's difficult to justify the expense. Otherwise, IMO a Micro-Air Easy Start is a no-brainer. :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
