westend
Dec 22, 2015Explorer
I believe RJ's mount is called an "L bracket". They can be found at Marine outfitters or on E Bay. You can DIY a bracket like this with standard aluminum angle and a drill. Typically, the solar module will have nutsert or some sort of captive threaded fastener that threads to the knob. I have a four-way tilting mechanism and all of it is attached to the other pieces with 1/4" pins and hairclips. Lots of different mounts that will work.
Deployed and tilted:
