dapperdan
Dec 22, 2015Explorer
Sagecoachdriver wrote:
Using the Renogy Z brackets, how difficult is it to remove the panels should the need arise? Can you get a wrench under the panels to remove the nuts and bolts?
Renogy roof mounbts
I would think difficult if not next to impossible. I mounted Renogy panels on my roof but I used DIY brackets I made from aluminum angle stock. I cut the pieces into four inch lengths and pop riveted them together making a "Z" out of them, then drilled holes for the mounting bolts. Using this method gives you the added space to get at the nuts and bolts to remove the panels without taking the brackets off of the roof not to mention added air space under your panels for better air movement.
I got the idea from here as several on this forum have used this method, works great too.
Dan
