BFL13
Dec 22, 2015Explorer II
Some (all?) panel instructions say never drill more holes in the frame or it will weaken the frame.
So if you go the side route, you need more holes. If you line up the bottom holes with the roof struts and you can't, you need new holes.
You can beat all that by having the roof attachments (rails, eg) to the struts and then you can space the existing holes in the panel to anywhere along the rails.
That still leaves how to get the panel off the rails without so much trouble. Depending on your set-up, you can use the two-bracket method or leave the bracket on the panel and undo from the rails
Which saves you from ripping up the Dicored roof attachment the other way with Z brackets.)
"It depends" (as usual).
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
