bid_time
May 08, 2025Navigator
That is a 30-foot trailer that has an empty weight of about 5100 lbs. Fully stocked with all your household goods it will likely weigh approximately 6500 lbs. That means the tongue weight will be closer to 750 lbs. (I assume you’re not towing the trailer with absolutely nothing in it). Add the fact that without a WD hitch the front tires of your truck will be unloaded by a couple hundred pounds. Now consider the likelihood of best case vs. worst case scenario. You willing to risk it?
DragonSpirit39
May 08, 2025Explorer III
I don't have much of a choice here, no money for a frame mounted hitch. Have to be out by the 28th. If I don't move it my landlord will and he'll drop it wherever one time and that'll be it. If I have to move it again I'm screwed.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
