Cactusface
Mar 12, 2024Explorer
Does anyone here know in a 1500 what the approximate weight you can put in the bed of the truck over the rear axle? Since it's a "half ton" does that mean 1000lbs?
blt2ski
Mar 12, 2024Moderator
You can put approx 2000 lbs over to slightly forward if rear axles.
Typical truck as you have will be 5000-5500 lbs empty. 2000-2400 on the rear 2800-3200 on the front empty. Both axles are rated at 3900 or so.
Their is an engineer or two that feel one needs to get you down to the lb as to what you can carry tow etc. from 40 yrs of running operating commercially class 1-6 trucks. I'm close.
Marty
- CactusfaceMar 12, 2024Explorer
What I thought as well.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
