pupeperson
Nov 11, 2007Explorer
blt2ski wrote: "The one exception that I wish they would look at, are Type A MH's, these the owners go by GRAWR< which can be as high as 25-30K lbs. There limit should be, if it is not already, 20K lbs, same as commercial!"
If you check closely Marty, I dont think there is a variance on the motorhome's from what the trucks can scale, axlewise. The M/H's that run heavy on the drive axles normally have a tag axle on them. They go up to 20k on the driven rear axle and an additonal 14,000 on the tag assuming they have the tires for it. That gives them 34,000 + 12,000 on the steers for a full 46,000 lbs over the 3 axles --- just like a 3 axle tractor or heavy duty truck. I don't think they'll let a motorhome run heavier than that.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
