Wadcutter
Nov 19, 2007Nomad
JIMNLIN wrote:
let me say this again. When we apply and operate with combined plates for a 3500 truck [example] the door tag GVWR and the trailers GVWR is added together to make my combined numbers.
And let me say it again. You are confusing weight laws with registration. They are 2 separate issues.
What you are describing for the way your state registers trucks and trailers is exactly the same way done in IL.
JIMNLIN wrote:
your interpetation of your state weight laws and what mcs laws your state enforces may hold true in your state but your mistaking other state interpetation of those laws.
IL's MCS laws are the fed MCS laws. Even the sections are the same. When IL adopted the MCS laws in the very early 80s it was done in toto. Those were mandated by the feds to all the states.
JIMNLIN wrote:
MY state will enfore door tag weights and is cracking down on non commercial users such as 3500 trucks pulling heavy construction equipment.
Once again you are confusing 2 separate issues.
I'm done discussing it with you. You have a mental block on separation of the 2 laws - overweights and registration. 2 separate sections and one not related to the other. It's impossible for me to explain it any clearer than I have. However, your mind is made up and you can't seem to separate the 2 issues. That's a clear indication of someone not fully understanding the topic.
grey`eagle wrote:
Given the excellent information posted above. It appears that we RV'ers can safely and logically come to the conclusion that we are not subject to the weight laws (in IL and AL) for our class as long as we remain under 26,000#s.
RVers aren't subject to MCS laws. MCS just doesn't apply. Just to randomly say MCS would apply if over 26K doesn't take into account what MCS would actually require. People think if MCS applies then they'll need a CDL. If it were only that simple. If MCS laws would apply then RVers would have to complete a log book, limited on the number of hours they could drive, would be restricted to not carrying passengers unless properly licensed, carry an extra set of glasses if they wear them, carry extra batteries for hearing aids if they wear one, would have to carry a bill of lading listing everything they have in their RV, and all the other requirements commercial drivers have to put up with. In addition, if RVers were subject to MCS laws then any certified law enforcement officer could stop the RV without cause, do a complete inspection inside and out, and a LEO could place the RV out of service for too many hours or defective equipment with fines up to $10,000 per day.
But the fact is none of this even matters. This thread is about weight laws, not MCS laws. Since MCS is even mentioned by some shows they have no understanding of what it is about and they're talking smoke trying to give the impression they're informed. If they were really informed about the weight laws then they would never have mentioned MCS laws since MCS laws are completely separate from weight laws and have no bearing on the topic.
grey`eagle wrote:
For those that don't quite understand the references MCS law , read the link.
Your link concerns insurance issues. MCS is a whole lot more than insurance issues.
grey`eagle wrote:
Based on my testimony before juries and Grand Juries, I strongly believe that the inference and comparisons of vehicle mfg'ers limitation decals to mattress tags will not hold up.
Mixing apples and oranges. This entire thread has nothing to do with crashes, etc. It's about registration.
The fed stickers are required by law for initial sales. After that point they are not required on the vehicles.
Oh yeah, and I have testified too, quite a few times, on criminal and civil cases as not only the expert witness but as the person who conducted the investigation.
grey`eagle wrote:
If I'm not sadly mistaken, the reference to paint color is not on the limitation decal, it's buried in the VIN number. At least it is on the GMC and Ford products.
Ford and Dodge sure does have the colors listed on the fed sticker. It's been a while since I owned a GMC. It will be a 1 or 2 letter code listed somewhere on the fed sticker, right along there with the tire sizes, tire pressure, and other data that have no bearing on the law. It's simply amazing that guys get their undies in a wad worrying about what the sticker says about their weight but don't think anything about the same sticker listing tire size if they change tire sizes. Again, it all goes back to not understanding what it is they're talking about.
Also, the color is not part of the VIN. All manufacturers use the same 17 digit VIN numbering system. All the VIN does is tell the manufacturer, model, body style, year, plant where it was built, a check digit, and the sequential numbers. Nothing about color.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
