BertP
Nov 27, 2007Explorer
I think that Jim has a point. If you look at the FMCSA regs, you will find the following definitions:
Gross axle weight rating or GAWR means the value specified by the vehicle manufacturer as the load–carrying capacity of a single axle system, as measured at the tire–ground interfaces.
Gross combination weight rating or GCWR means the value specified by the manufacturer as the loaded weight of a combination vehicle.
Gross vehicle weight rating or GVWR means the value specified by the manufacturer as the loaded weight of a single vehicle.
Notice that all of the definitions use the manufacturer's numbers. So, what will happen when a LEO needs to decide if a vehicle is overweight or not? In States and Provinces where private vehicle register their weight, no problem: just use the registered weight of the vehicle. But, what about States and Provinces where there is no registered weight for a vehicle? I can see a LEO interpreting the FMCSA regs to say that in the absence of any other definition, the manufacturer's GVWR as the reference point. Note that I amm not suggesting that that is how it is, just that that is how it may be interpreted.
Bert
Bert
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
