JIMNLIN
Jan 24, 2009Explorer III
"Actual federal weight law rules, some questions and answers"
is the topic at the top of the page in case your reading/comprehension level is aparantly at the third grade level. NO one has said FMCSA regs apply other than your blowing smoke trying to change the subject or cover your glaring lack of knowledge. What I said was as far as the door placard goes my states weight enforce officers use 390.3 scroll down to question #3 which says ; missing GVWR door tag. According to both officers Oklahome has a simular reg, that is used for commercial and non commercial enforcement, in our title 47 statutes that says its a misdeameanor to remove the door placard tags. Those are his interpetation not mine.
Your a typical dot officer we truckers run into on occassion and being required to carry the green book we have to on occassion show a self important dot officer what the FMCSA reg actually says. Your reading and comprehension ability is about like your description of a trucker says. I can blow smoke also or get just as mouthy as you get. Your choice.
As 10 ton says your problem is you say all states have your opinions on laws regarding door tag GVWR/GAWR issues and how other states use them. Your simply blowing smoke to cover your lack of knowledge on door tag numbers and how other/my state uses them for non commercial/commercial enforcement. The 390.3 and my states title 47 regs disproves the mattress theory.
Here is another NHTSA/DOT/FMCSA/FMVSS web for you to study for door placard issues that may be even a IL dot officer can comprehend.
49 cfr which are the same regs for commercial operators and non commercial operators.
flame on
flame on
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
