JIMNLIN
Feb 03, 2009Explorer III
(quote=jmramiller)
A direct quote from 10 ton's post " In the case of a private use pickup, it can only be registered for it's Fed label". This is not the only time he contridicts himself in the post. He also states that an insurance claim can be denied for being "overweight" which is absolutely incorrect.
Texas 502 registration regs
(quote)Sec. 502.055. DETERMINATION OF WEIGHT. (a) The weight, net weight, or gross weight of a vehicle, as determined by the department, is the correct weight for registration purposes, regardless of any other purported weight of the vehicle.
(b) The department may require an applicant for registration under this chapter to provide the department with evidence of:
(1) the manufacturer's rated carrying capacity for the vehicle;
(2) the nominal tonnage rating of the vehicle;
(3) the gross weight rating of the vehicle; or
(4) any combination of information described in Subdivisions (1)-(3).
Acts 1995, 74th Leg., ch. 165, Sec. 1, eff. Sept. 1, 1995. Amended by Acts 1997, 75th Leg., ch. 625, Sec. 3, eff. Sept. 1, 1997.
(/quote)
10 ton was correct just as he was about buying more weight for commercial use and private pickup. looks like you need some input from casper or some one that is familiar with your own state of TX registration regs as your knowledge is .... zero. If you knew anything about "commercial insurance" you would know that a violation of FMCSRs can and will lead to insurance dening coverage in case of a accident involving overweight issues. Like I told wadcutter if you want to trash talk I'll respond in kind. Your choice.
Your still blowing smoke trying to discreadit 10 tons comments and ingnoring the fed reg I posted about "missing GVWR placard". The 390.5 reg just proves the legality of the door tag which is what this thread is about.
Fed regs regarding door tag and how your/my state enforces those regs for a combined combo would be a better thread topic as too many are clueless about their owns state enforcement of those fed regs involving door tag issues and a combined combo. Also some, as you and others think, that my state enforces door tag as your state. Not so. I certainly wouldn't take someone claiming to be a LEO on a RV web advice over what your own state LEO.
The door tag GVWR in my state is used for commercial combined plates above 26k and axle capacity not covered in our max axle loads allowed/bridge law. Door tag GVWR is not used on the non commercial side in OK, which includes RVs, for a combined combo. In fact their is no gvwr on a oklahoma registration unless its for commercial purposes.
Door tag GAWRs/tire caps apply in my state for commercial combined combo. They also apply for non commercial combined combo which include RVs.
(/quote)
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 09, 2026
