mexicanpiloto13
Oct 26, 2023Explorer III
I just got this email from Blue Ox technical support on the type of bolts I need to use for the base plate that's used for the Hummer H2. They said: Those are just standard Grade 5 bolts. Should be able to pick up at a hardware store even. ½”-13 x 2” grade 5 zinc plated. Be sure to use red lock tite and torque to 78 ft. lbs. Also be sure to check the base plate and frame of the H2 for any damage before re-installing
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
