JIMNLIN wrote:
If I remember right the older 3500 srw Dodge trucks had 6200-6500 rawr (tire/wheel/rear spring pack). Your trucks drivers side door post certification sticker has the trucks fawr/rawr.
Drop by a set of CAT scales and weigh your truck front and rear axles separately.
Subtract the CAT scale number from your trucks rawr will give you how much in the bed payload you have to work with.
Those older trucks rear axle may weigh in the 3200-3400 lbs ...subtracted from 6200 rawr = approx 3000-3300 lbs before exceeding a tire/wheel or rear suspension.
This trucks rawr will more likely be overloaded.
The '05 truck has the AAM 11.5" rear axle good for over 10k lbs so its not a concern.
And of course if its the 5.9 Cummins it won't have any issues pulling that size trailer.
Many older 350/3500 srw truck owners with heavy truck campers...heavy 5th wheel trailer hitch loads upgraded to 19.5" tires/wheels...air bags of some type of rear suspension help
the 17in that i bought have a load rating of 3086 Pounds for one that should be enough for the camper then right. when i frist bought the truck i did put air bags on the back to help i would like to put an Exhaust break on it eventually
