StirCrazy
Jun 19, 2025Moderator
The FICM tests at 50.5 volts so that is most likely good
was that off or running?
if your going in to change 2 injectors that you suspect were caused by low fuel supply , change them all out and be done with it. you can get a good set of rebuilt ones.
if you can wait there are places that rebuild your injectors for about 800 bucks, if you can't wait it is just over 1K for a set. while your under the valve covers replace the glow plugs also, they are cheep.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 24, 2026
