monkey44's avatar
monkey44
Nomad II
Nov 29, 2023
Solved
Ford f150 Payload
Looking at F-150 to carry the Lance at 2750 dry.  Sold my 2500HD, and need a short truck to fit in my garage.  So, looked at GM 1500's, and payload says 1800-2200 lbs ... I thinking based on equipmen...
  • nickthehunter's avatar
    nickthehunter
    Dec 03, 2023
    Based upon my knowledge from when I was shopping for trucks 3 years ago; you could order a regular cab F150 XL 4X4 with the Heavy Duty Payload Package (HDPP), 18 inch wheels, and 8-foot bed. That would get you 4800 lbs rear GAWR and about 3000 lbs payload. You will likely exceed both ratings by about 250 lbs +/-; 4X2 will give you about 200 lbs more payload. That is as close as you will get to what you want in a 1/2 ton truck.
  • monkey44's avatar
    monkey44
    Dec 05, 2023
    Thx Grit-dog.. YEAH, I'm already going in a different direction ...  It looked like the truck were getting more Payload, but as it turns out the specs were calling out specific other options, but exaggerating the potential as usual.  I've been around truck campers a lot of years. That's why I do my homework first, and buy a truck second once I figure it out.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.246 PostsLatest Activity: May 17, 2026
