StirCrazy
Sep 01, 2023Moderator
noonenosthis1 wrote:
I have a 2015 F350 6.2 srw crew cab. I am thinking of truck slide in camper for long trips. How do I determine my truck's hauling capability?
What I do and others may disagree is figure out your true payloads. got through a weight scale that closed there, they leave the scales on. have a full tank of gas and you in the truck and nothing else. weight the front axles and the rear axles and write them down. then look on the door and see what your max axel capacity is for the rear and front axles and subtract your actual weights from your limits. that tells you how much you can load up each axel till you're at your limit. for camper weight I just go by the rear as some of the weight will be put on the front but not a lot.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Mar 27, 2025
