blt2ski
Sep 02, 2023Moderator
To add to stir crazy.
Try figure out the lowest deno.inator on rear, most important.
You may have a literal axle componant to 9000 lds, brakes to 8500, springs to 6400, tires to 6000.
Nothing illegal about adding a leaf to spring pack upping them to say 7500-8000 lbs. Changing from a 3000 lb tire capacity to 3500-4000 lbs per tire....
Now you have an ~7500 lb RA capacity, an additional 1300-1400 lbs of payload. Assuming a bit less than the 1500 gross, as the springs, shocks, tires, potentially rims may add a few lbs to the truck.
In Wa st where I am, I also have to make sure I have enough paid for gross tonnage, sold in 2000 lb increments. If you run down the road between 6-8000lbs, as I do in my 1500, so in his GM 1500, another son in his Taco! We three have 8000 lb registrations. Door sticker, normal 1509/ half ton registration of 6000 lbs would put us potentially finable for being over weight.
Multiple issues to deal with, to make sure you safe, AND legal!
Marty
Marty
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Mar 27, 2025
