jus2shy
May 22, 2016Explorer
Second Chance wrote:
I posted this on the Silverado/Sierra forum and got one response... "good luck." Since folks on this forum are more into towing than jacking trucks up to make them look macho, I'll see if anyone here knows of anything:
My wife and I are full-time RVers. Our truck is a 2013 Sierra 2500HD SLT CC D/A with the 20" wheel option. While the 20" alloy wheels look very nice, I'm having trouble finding a higher capacity tire than the stock LT265/60R20 load range Es that came on the truck. I'm looking for input on either: 1) load range F tires in the LT265/60R20 size, or 2) suggestions for replacement wheels in a size where load range F tires would be available without changing the outside diameter of the tire/wheel combo (currently 32.5"). I'm happy with the current gear ratio and the performance of the D/A when pulling our house-on-wheels. I could tolerate a slightly smaller diameter, but not anything larger (wouldn't mind a few more RPMs at cruise where the tranny would shift into 6th a little sooner).
The pin weight on our fiver as currently loaded is right at 3,000# which puts us just barely under the rear axle rating (GAWRR) for the truck when pulled across the scales (verified both on CAT scales and a wheel-by-wheel weight system proprietary to one of our RV clubs). The total capacity of the tires is a few hundred pounds above the axle rating, but I'd still like to increase that safety margin. I understand that no aftermarket modification (tires, air bags, etc.) can/will increase the ratings of the truck... it is what it is. I'm just looking to increase the safety margin on the most likely thing to fail.
You're probably going to need to go to a different sized tire. RAM and Ford have different sized OEM 20" tires. You'd get the cheapest 20" tires with the ford OEM size at 275/65R20 due to the sheer volume of superduties versus the other two brands. Those tires are rated at about 3750 lbs a piece versus the 3200 lbs a piece on your current truck. RAM OEM 20" tires are 285/60R20. These tires are rated at 3,650 lbs a tire.
To get the closest tire size, your tires are 32.5" Tall and 10.7" wide roughly. The RAM tires are 33.5" tall and 11.5" wide. Still, the dimensions are not that far apart and will probably result in a slight inaccuracy on your speedo. The Ford OEM size is about 34.5" tall and 11" wide. Tallest of the 3 and may be a fitment problem for your truck if you don't have any leveling kit.
Hopefully this helps a bit.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
