Bedlam
May 22, 2016Moderator
245/70R19.5 are about 33" tall You can get the rims in 4500 lb (Vision) or 5000 lb (Rickson) capacities. The tires are load range G or H and wear much better than typical LT tires.
These are Vision rims with 245's on my Ford:
The AAM axle in your GM is rated for over 10K lbs and the downgraded rating for your truck is due to the selection of suspension and wheels by GM.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
