jus2shy
May 22, 2016Explorer
therink wrote:
That is the reason SRW 1 ton trucks don't have the 20" wheel option available. I recommend going with 18" wheels and load rage E tires. The stock Michelin 265/70R18's on my one ton are rated for 3525 lbs.
I'm sure you know but no matter what you do with tires, it will not increase the load carrying capacity of the truck. That is a lot of weight for a 3/4 ton.
Just to ensure there isn't additional confusion with this comment, I hope you're just commenting on GM specifically. I personally don't know GM's weight ratings for GM's 20" rims. However for RAM and Ford, they both use 20" rim based tires I noted in my recommendation for 1-ton SRW vehicles. Feel free to check out their respective vehicle configuration tools.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
