Grit_dog
Oct 11, 2023Trailblazer
@reisender, since you have a fairly comprehensive EV knowledge base and years of use under your belt.
How much charge does a guy get level 1 off of a 120v convenience outlet at -25deg?
Again for context, if you drive low miles and are home a long time at night it may be fine.
If I have a 100 mile commute + (I do) and I’m getting home at 8-9pm and leaving at 05:30 and my Ford lightning (cause I need at least a little 1/2 ton truck, minimum) is sitting out in -25 deg weather and I’m using the Xmas light plug to charge it, how many miles of charge (roughly) will I get in that 8-9 hour timeframe in those conditions?
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.255 PostsLatest Activity: Aug 23, 2026
