4x4ord
Nov 09, 2023Explorer III
^^^You are correct. I think the diesel F350 crew cab long box with 20” wheels has a gvwr of 12400 lbs. The diesel long box super cab with 20” rims is 12300 lbs. I’m pretty sure all the 4x4 F350 diesels have the same rear springs and axle ….. the longer wheel base puts less weight on the rear suspension which I think is why the give a little greater gvwr to the longer wheel base trucks.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 03, 2026
