4x4ord
Nov 10, 2023Explorer III
spoon059 wrote:
So in theory, over 4000 lbs payload are possible, especially with lower lower trim levels. Those are pretty good numbers.
The payload rating is kind of a fabricated number in my opinion. I think the lower trim levels and or lighter engine options have lower GVWR numbers. I think you can get a little over 4000 lbs payload but not a whole bunch. (Get a lariat to get the 20” wheels but no sun roof for instance) I believe you need the long bed, the 20” wheels and the diesel engine to get the 12400 gvwr.
As an example of why I think the payload numbers are kind of fabricated take a look at my shortbox. It has the same strength frame, the same wheels/tires/brakes and the same suspension as a long box. So it certainly isn’t going to hurt anything for me to load my truck as though I have the same 12400 lb gvwr as the long box. And because the short box is probably about 200 lbs lighter than the long box ….. one could argue the shortbox should be able to carry a couple hundred lbs more than the long bed….. Although even if my shortbox had a 12400 gvwr it still wouldn’t be able to handle as heavy of pin as the long box. (The long box has less weight on its rear axle when empty)
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 03, 2026
