Looks like you're looking at a 2220ML trailer?!?
That should be very doable with your MB.
The one thing to look at is where are the tanks, ie water gray and black. The heavy item storage. With a bath, side kitchen, if those areas are behind the axles, you can run into a low hitch weight issue. But if you can load forward of the axles, you'll be better off.
I don't personally see an issue with you MB towing this trailer. Get somewhere, park the trailer, you have the MB to tour around locally. A class C, you have to tow a car around to your locally or take the MH. Danged if you do, danged if you don't.
You'll probably put 800-1200 lbs of stuff in the trailer. 750-800 lbs of hw. 6500 or so on the axles. No issues.
2 People etc in MB at 600-700 lbs. This includes CDs, wife's purse, food for trip, first aid kit, jumper cables etc that we all put in our rigs.
1400 lbs in vehicle for people and hitch weight.
Trailer at 26', probably as long as one wants on a 117" WB, but a proper WD/sway control setup assuming MB recommends one, you'll be styling!
My last post I forgot to mention payload issues. That's usually more of a problem than tow ratings. Been there done that!
Marty
CDs?
Lol
It ain’t got a CD player, so that should help w payload….hahahaha
- blt2skiNov 23, 2024Moderator
Grit,
The 2024 Subaru's don't give you an option of CD players anymore. Assume you would be paying for the new pay for radio option. So of course, CD's will not be in the vehicle. I was attempting to be rather broad in what went into the vehicle as far as my weights went. Maybe I should have used cassettes, or heaven forbid, them 8-track thingamajigs!
Yes this thing is about the size of a tahoe or equal. It does have some ability to handle the trailer just fine! Some of the issues that may occur, if it has some kind of ride height airbag load leveling system, WD bars or equal will be out the door. Same with other full-size SUV's.Choose ones poison for what is best for you or me or __________!
Marty
