JIMNLIN
Oct 20, 2023Explorer III
sound like a fair deal for a pre owned '23 2500 LTZ DMAX/A.
2500 GM diesel trucks can come with up to 11550 gvwr and higher rated 6600 rawr .
Rawr will carry all the pin weight and other stuff in the bed so the rucks chassis and the DMAX/A will have no issues with a 12k 5th wheel trailer.
My neighbor has the same in a '22 model and pull my fully loaded 36' tri axle 21k lbs stock trailer with ease.
If your trailer has the notched/rounded front corners made for short bed trucks I doubt you need a sliding hitch if the pin is located zero over the trucks rear axle.
GM has a 43" C/A dimension (cab to trucks rear axle)...longer than Rams or Fords C/A.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
