wintersun
Jun 24, 2021Explorer II
For the most comfortable ride the best class 1500 pickups are the ones from Ram which have coil springs on all four wheels. Advantage of a crew cab pickup is havingt the rear bed for cargo. Add a fiberglass cap and you can use the space for gear, like firewood or a dog, that you do not want inside the cab or the trailer. Also adding a roof rack makes it relatively easy to transport kayaks.
Order the truck with the larger fuel tank and the electronic locking rear differential and the 3.92 rear axle ratio and the truck can tow up to 12,000 lbs safely. Add the Trailer-Tow Group to get the trailer brake controller, trailer TPMS, and trailer reverse steering control.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.256 PostsLatest Activity: Sep 03, 2026
