mosseater wrote:
My only real complaint with 7.3 is, in tow mode the minute you touch the brakes going down even a moderate slope, it downshifts too low for the speed I'm carrying, so Im going down slopes in 2nd gear screaming at 5000 rpm until I ease into the gas again. I find sometimes its easier to use manual and pick the gear I want. Towing about 8200 lbs with my 3.55 I get about 9-10 on rolling hills. 11 on flats at 65. Otherwise, I have few complaints about the truck. (except that gas cap lanyard.....argh!)
With my Ford I also do a lot of manual control of the gears. It seems to be too eager to down shift when the brakes are applied in tow haul mode and not eager enough to downshift when climbing hills. I would like to have the option of customizing some of the tow/haul settings, including different settings for different trailers. I don't see how that would be hard for Ford to do with everything already computerized.
