PA12DRVR
Sep 15, 2020Explorer
"Am curious and ask you all who think warranty ratings do not mean much...do you all follow the ICE's RPM rating ?
AKA....tach red line for your ICE
Or Coast Gaurd max occupancy for all certified boats ?
Ditto elevators, airplanes, etc"
Not the target audience since I at least factor in the mfg. ratings, but: a) always watch the redline on the ICE's, more carefully on the 0-320 on the PA-12 than the engines in surface vehicles; and more carefully on the KEM on the boat than on the pickemups; b) I am aware of the CG max occupancy for my boat, but never come close since I like to run in skinny water; and c) always factor in the Gross Weight limit as well as balance calcs on the ol PA-12; and d) exceptionally claustrophobic, so avoid elevators as much as possible.
I have a 2006 Wrangler Rubicon / LJ that I use every so often to spot the boat and sno-go trailer around the property. Works OK for that, but, since it's the original gutless wonder, can't imagine towing with it.
About Tow Vehicles
From fifth wheels to teardrop trailers and everything in between.254 PostsLatest Activity: Aug 19, 2026
